sixgun86gn
six offender
- Feb 10, 2002
hey guys.My new motor is running good at part throttle.But if I jump on it,it pulls out a lot of timing in first ,then takes off like a rocket.The car pulls real hard after it stutters real hard and shows Kr anywhere from 11 to 18 ,in other gears there is almost none if any.I have tried to rule out mechanical knock by revving it in park and it is fine.At first I thought it might be the t&d rockers but I dont think so now.I really need some advise before I blow up a new motor trying to tune it.The fuel pressure is at 44# idle.I just installed a 206/206 cam and ported heads and intake during the rebuild.The injectors are msd 50s,chip is a MM street chip for 93.everything else is the way it was before and it ran great at wot.I did notice that loosening the TV cable helped,should I try loosening more?It acts like its hitting a rev limiter,in first but shifts throuh the other gears fine.Any help will be greatly appreciated.
