Need help!!!
vl1500
Can someone help me with the wiring of my engine control unit.I purchesed a used fp performance sefi8lo unit and it did not have the wiring instructions.It appears to be a straight forward install but I spent a lot of money on it and I would hate to wire it up wrong.My question circles around the pink/black wire thanks.....
The help section in the software shows the pin out. If you look at the connectors you will see that they have tiny letters on the pins and numbers on the side of the connector, loook very closely. Find out which pin your wires go to , the grounds should be on Y1,Y2,Y3, and main power +12v battery should be on M1. Your wire colours may not match what is shown here on the chart but as long as you know which terminal its in you will be ok.
