Dutchboy
- Aug 30, 2008
I have a 87 Gn that has never ran right. The person I bought it from was suppose to tune it but never did so Im having to do this on my own with no prior Buick knowledge. I have T-link 4. the car is a Bitch to start once running it idles at these values.
725-850 Rpm
Tps .43
02 Voltage 51 Mv-66Mv saw it as high as 150
02 Cross Counts 0#
Alt 13.4
Mixture is Lean
Spark Ret 0 Degrees
IAC 91 36%
Mat 90.0
Load 50#
Integrator 128
Blm 150
If anyone can help me with my problem it would be greatly appreciated. I do not know how to change these values but would like to learn if any of them need to be changed. The Gn will start the first time kinda easy but If I turn it off and try to crank it again it takes FOREVER TO get it running. I really just want this car to start better to its not almost draining the bat everytime I try to start it. Its kinda embarrassing. I would like to take it out more but it runs like a turd. Please help guys!!! Thank you in advance..
725-850 Rpm
Tps .43
02 Cross Counts 0#
Alt 13.4
Mixture is Lean
Spark Ret 0 Degrees
IAC 91 36%
Mat 90.0
Load 50#
Integrator 128
Blm 150
