HRpartsNstuff
- May 27, 2001
I am looking for some real world (honost) HP and/or Torque numbers for a 231 V-6 TR with a stock turbo on pump gas. This would be at the 15-17 psi range max, and chassis dyno and/or engine dyno numbers welcome.
PLEASE, NO guessing and/or estimates, already got those
Also, prefer WITHOUT the aid of alcohol or other "power adders" like octane booster & such.
Also, it can be with just about any other upgrade, doesn't matter. Heads, headers, downpipe, injectors, regulator, adj wastegate, fuel pump, etc, etc..., just HAS TO BE a stk turbo.
PLEASE specify if using the stk intercooler, stk intercooler with neck mod, or aftermarket intercooler.
If you have a car weight & actual drag results, that helps too!
THANKS IN ADVANCE!!!!!!!!!!!
