I am going to replace the rear deck factory 4x10's. Want to know what is the best sounding speaker to go with? Will be having the deck cut to fit for 6X9's. Also have two Sherwood 125 watt rms amp's one per speaker. Also will be replacing the front deck speakers using deck power what speaker combo will work with the rear deck and also doing the doors speaker. I do not want to cut out the door panels. A single 125 for the door speakers. I also have two Cerwin Vega 12 inch subs behind the rear seat they are mounted on 3/4' particle board. Will I have any problem with sound as the deck speakers and the subs are open to the trunk . If the is I have a friend that has a program to make boxes for the rear deck speakers which he said would be a pain but could be made.
Thanks in advance. AJ
I am not concerned about cost want the best speakers also realize that the most expensive is not necessarily the best.
