Need part number
aquickv6
Could someone please provide a part number for the black trim piece that goes on the pillar post nearest to the 1/4 panel. It's the wide piece that goes under the strip that holds the weather seal for the window (4" wide) Thanks
These are for a solid roof car. Post back if you have T-tops.
Left side 20623661
Right side 20623660
Both numbers have been discontinued for years.
These are also Buick only. You can use ones off of another G-body. The only difference is in the raised pattern on the molding. Mone of the other models are available either.
It is a solid rood car and I need the drivers side due to a small ding in the piece. I didn't know it was discontinued. I guess I'll have to live with it.
Thanks for the info.
