Need Quick Help!!! Were Is The Fuse For The Fan?
87grandnat
DOES ANYONE KNOW WERE THE FUSE FOR THE FAN IS, MY FAN DOESNT WORK AND THE FUSE IS THE ONLY OTHER THING THAT I CAN THINK OF BUT CANT FIND THE FUSE FOR IT, THANKS FOR ANY HELP
If you're speaking of the engine coolant fan, the FUSIBLE LINKS for it are down by the starter motor wrapped up in the looming material. Come to think of it, the heater (fan) motor is in the same place!
Could.
My fan failed when the fan itself quit. Check for 12v across the fan, I found, after much troubleshooting, the easiest way to check the fan is to remove it & apply 12v across it from a battery charger. GM wanted $285, Ramchargers, shipping & all was less than $100 for they're dual fans.
