Need SD2 tune for 60# injectors and 91 oct
greeneyegi
I put my SD2 from one car to another. For some reason this is way off.
My car had alky this one doesnt. I just need a closer one without alky.
thanks
Do you have any logs ? Have you reset it to the default tune?
okay do you have any logs you can shoot me ? I can send you a default stock tune if that helps you ? u have a email?
Look at your MAP reading, 140kpa with the engine not running, 110 idling.
You'll need to get that straightened out before you even start the car.
MAP should be about 100kpa key on/engine off.
I zeroed the map with pl.
The numbers are within range now.
I am having an IAC issue.
With the engine oft, its 140.
Start it and it goes to 90 ish for about 3 seconds then 150.
Adjusting the screw doesnt do anything.
I unplug the sensor and start it does same exact thing.
It runs exactly the same unplugged.
Zeroing the MAP in PL would not have fixed your issue. There is something wrong with the MAP sensor or wiring or plumbing.
On the IAC, could be a bad IAC or wiring since it's not responding.
