Need some Expert Advice Here!
my1stgn
Im having problems installing the Billet Aluminum Servo from CK Performance. I had it installed before and all was great but now Im using a different wide band so Im thinking its not lining up right maybe? I cant get the piston all the way in to install the clip. I even used a clamp!:eek: Here are some pics of where the wide band anchor spot is at for the pin. Is this too low? And also, does the button for the band look too side ways (angled?) thanks!
Poke a screwdriver through the servo pin hole to put the band anchor into the correct position. Use one hand to hold the band in position through the bottom of the case and remove the screwdriver. Install servo assembly.
Sometimes you can position the anchor, remove the screwdriver and install the servo without having to hold the band. But, to play it safe hold the band through the case, or have someone help you hold it while you install the servo.
ROOKIES!:tongue:
Ummm..... I knew that! :biggrin: ......... But yeah, I think I might just turn in my ASE Patch for Auto Transmissions after this!:eek: ......... Thanks again Donnie! Ill bring some more donuts next time I come by! And low fat milk for Wayne! lol!)
I went from an Alto Band to a carbon band and had to totally reset the and clearence.
I didnt do any measurements but I did check to see if the tail shaft spun clockwise with it not engaged then used air to check to make sure it locks. Looks good so far!
You're the best!
