SignUp Now!Or just get the 80lb High Imp. injectors and don't worry about it. No need for ECM mod with these. I'm thinking of dumping my 120's and going with 160's. It's fun running 30 pounds of boost+ on E85
. I will need to beef other things up once I start getting close. For now I am looking at E85 or close to straight E85 at about 20 to 25 lbs and the mid 12's
QUOTE]
If all you are looking for is mid 12's then 50 or 60 lb injectors will be just fine. I ran 50 lb injectors with a TE44 last year.
Apologies for de-railing the conversation. Rest of the discussion was moved to here:
http://www.turbobuick.com/forums/ge...h/280343-fulep-pump-injector-cheat-sheet.html
Where is your info for this?
So the gas guys run 83's could not possibly run a 340?????? Hmmm???? There are a lot of guys that are really screwing up their cars out there.
This is at WOT, the car will never reach anywhere near 100% duty cycle at 15 psi
What if it needs to due to changing conditions? Where's the safety margin? Let's say it's a hot day, the air is dense, timing is a degree or 2 high, got some less than perfect gas, wastegate is holding a pound or 2 too much boost, etc. Then what? If for some reason you need the extra fuel, the pump won't be able to keep up and your pressure drops. I'm not saying to go crazy. Just plan/size things accordingly.
What is the best way to monitor the DC % ??
Will the 340 pump and stock fuel lines support 79# injectors at 20 - 25 lbs of boost??
What is involved in adding a WB and will I need a power logger?
