need tranny help ASAP, how to fix the governor springs?
TType84
cookin with propane
alright.. blah blah blah.. the springs came off my governor.. dropped the pan, dropped the gov cover. found one spring in the bottom of the cover.. the other spring is MIA. are they both the same size? if not.. can anyone point me where to look? i need to have this thing back together asap and i figured it would be an quick job, and it would be if i knew where to look for the other spring.. ideas?
Actually, the GN sometimes had two springs also. We have brand new GM parts with one or two springs. Don't know the logic there, but its a reality. If it had two springs, they are of different tensions. TCI has the spring you need though. Mark:D
thank you guys.. i got it all bolted back up and its all gravy now.. :)
