need turbo help
bearnone
joe bear
i have a 85 gn i need to :confused:replace the stock turbo i think its the ta33c or could i get a different one that would bolt right on and where could i buy one thanks for any help
You have a Ta33 that needs service ? Just send it out to get rebuild, try blasstperformance, i think it's 150 plus shipping(to/from canada) ust make sure you want it just as it was, same seal etc etc. I think hotair needs carbon seal not dynamic.
Or try some other turbo rebuilders, some members should throw some names out, gpopshop.com etc
Precision Turbo in Indiana can take care of you as well. They are on this website as well. Brad
for those more who are a little more adventurous........
carbon seal back plates are available for most any turbo application.
A.j.
im sorry about all the questions.does a ta49 fit. lol thanks
The Precision TBO 330 is a stock hot air turbo. The TA49 is an intercooled 86/87 turbo upgrade which will not fit unless you reclock it, make a turbo adapter and change the seals to carbon. You can have Precision convert your stock turbo to a TA33C which is a TA49 compressor installed in a hot air housing. This turbo is the only bolt on upgrade available for a hot air. Brad
Not true any more Brad. The good dr has been making some upgraded backing plates so you can add a bigger turbo to a HA car.:biggrin:
This is good to know and it gives me bad ideas which a long cold winter will surely kill off!! Thanks- Brad
Send Aj a PM and wait on a response Brad. He really does have some special parts to upgrade both the C/T and the HA cars.:biggrin:
Here are pics of a 87 Turbo modified to fit a HA car... notice housings been rotated (reclocked) as well
look familiar dr frankenstein ;)
