Need wiring help w/ 2007 PAC kit...
WH1
5150
I have the low level bulb (brown & orange wires, Tan wire from the tank and brown & orange wires from the PAC box. I'm guessing the 2 brown & tan get wired together? And the two orange wires together too? I have the underhood green and a green from the PAC box, these together? This leaves only the red wire & black wire form the power inj. bulb. The block has three terminals, one looks to be the ground or bare wire from under the hood. What goes to the other 2 terminals? I have instructions but they're from a newer kit and a little different so thanks in advance for any help. David
The PAC unit has an orange and brown wire coming from it. There is a clear colored LED that has orange and brown. Simply connect orange from led to orange from PAC. Brown from led to brown from PAC.
The tank has a tan wire coming from it, there is a red colored led that has a rubber grommet on it. That led will have a tan wire and a red wire. Tan from tank to tan on led. Red from led to +12
Pump cable.. Strip pump cable and you have red, black, and bare wire. Connect red to + terminal on block, black to - terminal on block, and bare wire to o terminal on block.
Green from map to green on PAC
Don't use gray or violet wires
Done
Do not connect tan wire from tank to brown wire on PAC as that will make a mess
Done
Thanks for the info, Julio. David
