salvageV6
Daily Driver
- May 25, 2001
Maybe tomorrow at work if all the digital cameras aren't stolen already.
Need a place to host them however.....
SignUp Now!you can do a pretty accurate measurement of section width of mounted tires by using a pair of metal carpenter's squares. Hold one pair of legs on top of each other, the remaining set of legs will act as "jaws" . The jaws measuring the tires will be be parallel. This may sound more complicated than it really is.Originally posted by salvageV6
Will try to get a better measurement of the midpoint if we have large jaw calipers available.
Jim put the molding back on your car and let me know if they rub.
Couldn't tell if the lips are rolled either on your car?
Mine is stock with the molding.
Most of the cameras have disappeared there may be one left out there I will check soon.
Tires are on the car so the inside measurement device has to clear the shock mount area.
Got about 4-5 inches to work in there.![]()
They don't fit all that well on a driver with 3.5" backspacing and an 8" rim. Really.![]()
