SignUp Now!Is it possible to give us the Scanmaster display readings?
You might want to remove the IAC from the housing and clean any carbon or gum off the tip of the plunger and clean the seat as well.
once you clean it follow these instructions:
http://www.vortexbuicks-etc.com/basics.htm#IAC (Idle Air Control) Adjustment
and this one since these adjustments work together
http://www.vortexbuicks-etc.com/basics.htm#Throttle Position Sensor Adjustment
I thought that screw was idle set screw but the link shows to adjust it down to iac of 15-25. I can't even get it that low
I did clean and reinstall iac already...how do I reset the tps? Thank y'all for the help!
You do realize according to this site:------------ http://www.vortexbuicks-etc.com/basics.htm#IAC (Idle Air Control) AdjustmentCar runs pretty good! IAC count around 55 and rpm around 1500 when in gear and idle. but otherwise runs great! Thank y'all!!!!
