hemi8
Goin Sideways
- Jun 6, 2001
I was working on installing the Baer rear disc brakes and when we came to the combination valve the fun began, about half the brake fittings were rounded off with a S-K tube wrench. I thought it would really bite working with brake line but it was a cinch. I used a new tube called Poly Armor, easy to bend even with your hand, easy to double flare, even with my POS China made Jegs double flare tool. I also found the Eastwood tube bending pliers very helpful. I found that you can purchase the gravel guard seperately, per foot. One of my rear brake lines got kinked during the install so I needed to cover the new line with a gravel guard. Simple simple compared to the old days, easy alternative to Classic Tube who got on my bad side with their ill-fitting SS trans lines.
Gravel Guard: Brake Line Spring Wrap
Poly Armor: Products
Eastood Pliers: Eastwood's Brake Tubing Pliers
Disk-Disk Combination valve needed for Baer Kit part PV4: Proportioning Valves - Pirate Jack - Hotrod, Restoration, & OEM Auto Parts
Mike
Mike
