new catch cans
QUIP'6'
Brian Roman
bought this catch can on ebay for $8.88 NEW IN THE BOX!!!!! cannot believe it how did they make any money. its all aluminum with all the mounting hardware. i guess they have a bunch of them
Shipping/handling probably cost you $20.-25.00 right??
HOW
Haynesie said:
what is the point of these and how do they work? pics of install?
keeps oil from getting in throttle body our cars tend to suck oil vapors from pvc valve into throttle body and cover intake, valves and gum up everything also lowers octane levels this can has two openings one goes to pvc and the other goes to throttle body so under normal vacuum the oil drops in the can and falls to the bottom and clean air goes to the throttle body when oil starts to show up in the eye glass just open the drain on the bottom of can. i'm going to put it on a fresh rebuild so if you get one on a car with miles on it its probably wise to do a couple top cleaner runs also the amtech ones are now 160.00 boy what a difference in price
Looks like my Deli's coffee canister with that sight glass on the front :cool:
its 1/4 inch thick aluminum i dont think your coffee was cheaper than this
Can you send an E-bay link for the auction on these!!!!
Currently run the Tompka check valve in line with PCV, couple thousand mile's , so far,so good.
Also.....do a "muffler" search on ebay and find mufflers for 4-6 bucks that are stainless steel....
tell me how to put link on site and i will tell you i been trying to put it on but it wont let me look under aimspot 2000
it's easy
Just got one, Go to Ebay.com go to advanced search, then search by seller, type in aimspot 2000 and hit enter. Then after it comes up go to view sellers items and you will see it eventually the guy has over 30,000 transactions with a 98% rating. :wink:
Just go back into the recent auction you just won, and copy, repaste the thread onto this site, and we will be able to go in and view sellers other items.
These look like real nice cans compared to the other pasted on this site.
I ordered one.
Nice link to the valves and Nalgene alky. bottles too. :cool:
Personally I think his feedback kinda sucks but then again I did survive the Mease downpipe group purchase. ;)
salvageV6 said:
I ordered one.
you will need to purchase a 3/8 check valve for the can and unscrew the two top bolts and lift off the inlet pipes. it comes with gaskets that need put on i used pewrmatex to give a vacuum tight seal also one inlet has a 1/2 in drop and the other entry inlet has a 1 1/2 inch drop tube. the long one goes to the pcv and the short ones goes to the throttle body
