NEW Custom built CK performance OD trans package
buicksstage1
FORSALE: Custom built CK Performance AOD Transmission (w/4R70W gear set) w/trans-brake and JW "Ultra shield" Bellhousing to fit GM w/locking dipstick and extra 2.5 qt cast aluminum pan coated with Swain "BBE" to help further dissipate heat, (about $4000 here alone!) B&M Pro Ratchet Shifter reverse pattern for Custom CK Perfromance (TurboBuick.com sponsor)
AOD w/brake, Pro Torque 3500 stall non-L/U 10" convertor, PermaCool
"Maxi-Cool" transmission 6-passCooler w/10" fan(12318) w/install kit,
G-Force Fabricated Transmission Crossmember. Well over $5000 invest in all these parts and trans and torque, everything is new. This trans is rated up to 850ftlbs. I would like $3000 for the package. Parts are located in Decatur IL and would prefer pick-up. This is forsale on other websites. Chris
