I have a 1987 grand national with a new engine built stock with a ta-49 turbo, has underdrive pulley, cold air intake, and a different maf sensor for the only mods. I plan on putting in a hot wire to the fuel pump an adjustable fuel regulator and a set of 42# injectors that came with the car. What should I set the fuel regulator at. Should I go with a bigger stall or will the factory one do. What boost should I run. The car came with three different chips don't know what they all do, the one that was in the car worked good all it says on the chip is mag-IV, the other one is an art carr power max 16823 E7F26, and the other is a hyper tech pt# 41 373. Should I go with any of these or should I get one programed for my car and if so what would be the best place to get this from.
All this car is going to be is a driver and when some one pulls up and thinks that there car is better than a grand national I would like the car to be at least respected, maybe take it to the track a few times a year to race some friends (only an 1/8th mile track).
What other mods do you think would be a good fit for my car for what I want to do with it if any more mods at all. Would meth injection be right for my set up, I was also told since I have bigger injectors to run e-85, it has a higher octane and I can run more boost.
This is the first turbo car that I have ever worked on, so I don't know alot about what makes these cars fast. I plan on keeping it for a very long time so I don't really want a race car only for the track I would like a car that looks good and to drive with the a/c on and still be able to smoke alot of other cars. I would appreciate any advice.
