crazyttypechic6
- Mar 11, 2014
So after a long year of being down...we have rebuilt the 87 Ttype - made some up grades from flat tappet to a roller valve train, changed cam (212/212) nothing major, went back with copper head gaskets, Harland sharp rockers, comp lifters, new bright and shiny headers almost the whole 9 yards . Finally getting around to finishing it up installing all accessories and major components, set crank sensor, set cam sensor installed battery was about ready to install new chip and try and build some oil pressure when we filled the vehicle with coolant. Now we have a coolant pour from the back of the engine. It seem to be streaming back running down oil pan due to the car still up on ramps- BUT that's not just it - pressure tested the coolant system - under pressure it poured - same area - checked all freeze plugs we could get to, all seemed fine noticed at the front bottom of the drivers side head up in the corner where the head meets the block some bubbles - really? It couldnt be - so jump up to check the dip stick notice oil drilling off the dip stick and beading up when we whipped the stick clean. Got back under the car put my finger at the base of the dip stick tube and the oil would re-route from running down the oil pan to running down my finger.
I do not understand how this could happen. It has not seen its first crank - this engine was built by a reputable builder for the area here - am I just in disbelief that this could be a head gasket or could this be something else happening?
