Hello,
I am going to start-up my newly rebuilt engine tonight and wanted to share some thoughts and questions.
Here’s what I have done so far:
Filled crankcase with 4 quarts older Rotella, 1 quart newer Rotella, one bottle Comp Cams break-in additive, and ~1.5 quarks Mobil One. If you’re doing the math have a remote filter so it takes about 6 quarts and there’s about 1 quart on my garage floor.
Turned the oil pump with a drill to pre-lube engine, rotated crank, pre-lubed, 3x. I had oil out of all the push rods. Question here: it looks like some of my lifters are not pumped up since I only saw one or two of the valves open during my pre-lubing procedure. Is it normal for the lifters (new Comp hydraulics) to be not pumped up until you start the engine? Will it start-up this way?
My plan is to start up and run 30 minutes about 2500 – 3,000 RPM by putting a shim between the throttle bracket and idle screw. Does anyone know (or can they check) how much gap there is between the bracket and screw with their car running about 2,500 RPM.
After this I am going to change the oil and filter then drive it to break-in the rings.
ANY further thoughts or tips for start-up would be welcome.
Thanks,
Dave
1987 Regal T Turbo
Thanks,
Dave
1987 Regal T Turbo
