hello my name is Brian and i am out of NW Arkansas, i recently traded an 81 camaro i restored and an 85 monte carlo SS for my absolute dream car, 1987 Buick Grand National, but i have an issue.. im very good carb'd engines but dont know anything about fi or turbos, im looking to have a dependable car that is low 12 high 11's if possible,
I got the car late thursday night.. and was drving it home and anytime i would get into boost it would spark knock so i never got in it hard.. i went and put the highest grade fuel (91) in it and it still seemed to spark knock.. i drove it for about 90 miles and started stumblinig anytime it would get into the boost and progressivly got worse to the point it started backfiring and lost all enigne power, it sounded like a lifter ticking, i got home and pulled the valvecover off and the #1 intake valve rocker was very loose and when we turned it over it didnt hardly push the spring down. so im pretty sure that the cam went flat. i hear that these 3.8's are notorious for oiling issues.. now where im at is needing a cam and lifters.. i dont want to swap out springs.. is there a suggested cam i can use? i list what i know about the car
has a tune - unknown
LS1 MAF swap
K&N filter
60lb injectors
everything else is stock other than the transmission 200metric (supposed to hold 600hp)
id like to get into the low 12's high 11's and be dependable with cold a/c
LS1 MAF swap
K&N filter
60lb injectors
