NEW GM MOTOR w/extra parts
qwknuf6
100% STREET CAR
I went and looked at a GM hot air mtr , It's Brand new ,Mtr was complete from intake to oil pan still in a crate . Things that come with it are ....Turbo, frt cover and cam sensor , Turbo, headers , fuel rail and inj's ,braided stainless steel exh pipe, coil pac and module . and many other brackets and even the original plug wires , all this stuff is NEW GM PARTS!!!!!!!!!!!!
Any one interested , I can get the whole deal for 1300.00
Mark
yeah im interested let me know on more info is the engine good to just drop in and will start up? and what else does it need or do u mean its completetly complete? well if u still have it around hit me up here or at my email address at lilslugger00aj@yahoo.com thanx
Motor is a long block ,which means it has block ,crank , flywheel ,rods ,pistons and rings and brg's all assembled . the intake and oil pan are on the motor also .the timing chain and cam are installed on the motor along with the cycl heads .
Things with the motor but not installed are frt cover and cam sensor , headers and braided steel exh pipe , coil pack module and braket , fuel rail , turbo with wastegate , the5re are other parts that go with it also , I would insp the motor carefully as I would any engine I would be building or installing ,all parts appear to be new with gm stickers and such still on them .
Mark
ok so it seems reall good to me but what do u mean by long block ? 3.8 or 4.1 and what yr engine is it ? is it a GN 86 87 wit turbo in front or 84 85 wit turbo in the back? how many miles on it ? or do u mean brand spankin new?
That was covered in my last post.
(QUOTE)3.8 or 4.1 and what yr engine is it ?84-85?
It is from 84-85 block casting #25514290 .There was no 4.1 Turbo block offered from GM.
(QUOTE) is it a GN 86 87 wit turbo in front or 84 85 wit turbo in the back?
see first post ,its for a hot air car
(QUOTE) how many miles on it ? or do u mean brand spankin new?
Again see first post
Maybe we should read the post more carefuly before asking ?'s that have been clearly covered .
Thanks Mark
hey yeah sorry about those dumb questions again its just that wow all that for 1300 just got me a little excited ok so where r u located ? and who is sellin this whole engine setup? where did that engine come from ? u got any pics or info of where this engine is located?
No problem ,I will anserw all the ?'s I can
The engine is in my garage , I purch'd it from a local GM dealer in Tulsa OK .No one knew why the engine was in the dealership , it looks to have been stored really well though , they were just cleaning house , someone called me because I am local Buick Guy that works on GN's ,they told me it was a 87 gn motor but when I got there I told them it was 84-85 motor ,they just didnt know, it will make someone with 84-85 motor a real good deal , I know those parts are hard to come by , It's not everything but it is alot of stuff.I have worked on a few of the 84-85 cars,they have alot of different parts '
I am in Claremore OK , just outside of Tulsa
Mark
hey
i am pretty sure i will take motor if you could call me or i could get your # i would like to arange shipping or maybe i could drive up there and pick it up? i live in tucson arizona on Davis Motham Air Force Base. My # is 520-248-0793. how much do u want it for. if 1,300 consider it sold. is it possible to send me some pics to Boost231@cox.net
brent:D :D :D :D :D :D :D
Brent
I do want 1300.00 for it , You are second in line . there is someone in texas that spoke for it first , you are the 2nd peson that said they will take it , The deal is supposed to be done next sunday , I will let contact you if the deal falls thru ,
Mark
I know someone w/ one of these(well similar) it was a VO-TECH engine that was never fired b/c it did not come w/ the headers. EVERYTHING is on the engine and ready to be fired up for the first time!!! ive seen the thing and was pretty amazed to see what a BRAND NEW hotair looks like.....pretty neat....he also said they put some liquid or lube or gel on the internals or wherever to keep everything new and not rotted....dont know much about it but I think if was going to sell it he was looking for a little more than 1300 so this is a GREAT deal!
