turbo6leon
- Jun 7, 2001
My new motor is running extremely rich. I've reset the cam sensor a dozen times & nothing changes. I bought new 009's & RA93 chip after starting this thread - http://www.turbobuick.com/forums/showthread.php?threadid=45873&goto=newpost
& still no change. I've tried 2 different, known to be good mafs, swapped o2 sensors & just about everything else you could imagine. It starts right up every time but is just dumping butt-loads of fuel. While priming the oil system the key was inadvertently left on & the fuel pump started running when the oil pressure hit a certain point. Could this have caused some sort of problem? Could something have happened to the ECM? I can't find any wires that are unhooked anywhere or any that are pinched. I'm grasping at straws here. Unless somehow I'm $ucked up with the cam sensor I don't understand how the fueling can be so screwed up. Any ideas? I NEED HELP!!! What am I missing???
Thanks,
Lee
Thanks,
Lee
