kustomwerker
- Jan 6, 2007
i just put in my 2004r trans a little while ago, and just finished it up today...it was rebuilt, and then sat around the shop for 4 yrs...before i put it in, i changed the vb to a bto unit that had also been sitting for a while...trans shifts very positive from 1-2 and ok 2-3, but wont kick down, and no od...sometimes wont go into first when at a stop...starts off in second...when in 3rd, l-u works...when shifted into od, it stays in third...if you let off the gas, it will freewheel to idle, and if you get back in the gas, it goes right back up to 3rd...no slipping...if in 3rd, it will not freewheel down...converter is about new, with only about 15 miles on it, and is also a bto unit...2400 w/l-u...maybe stuck valves in vb???any help is greatly appreciated...you guys always come thru on the 2004r stuff!!!
