New Personal Best 10.71 @122.61 On the Hot Air
turbo6x2
10 second hot air
Well we made it to the track one more time and the time slip looks like this from Martin Michigan
r/t .5052
60ft 1.4936
300ft 4.3138
594ft 6.3017
1/8 6.7509
1/8 mph 100.19
1000 8.8857
1000 mph 113.65
1/4 et 10.7148
1/4 122.61
air temp 50 degrees. Was so great!!!
wow. you using the T-Brake?
No, that never worked and was after this was installed my transmission wouldn't work anymore, swapped out valve bodies and now I can run my 200 r4 again. I leave with 12 pounds of boost off the foot brake, I can hold up to 20#'s on the foot brake and I'm pretty accurate when I race. The pass just before this was a 10.86 @ 121 with a 1.5058 sixty foot time. I do think the cold air made a huge difference as well. The 10.86 was right off the trailer and an hour later I ran the 10.7148 @ 122.61 then couldn't hook and wasn't leaving with enough boost or too much.
Thanks Al I know a lot has to do with my tin man air intake set up I have on the car.
Jamie
