Racetronix
- Oct 1, 2001
NEW RACETRONIX DUAL IN-TANK FUEL SYSTEMS
FEATURES:
HARNESS FEATURES:
FEATURES:
- Stainless-steel sender and pump mount
- Anodized billet aluminum pump coupler
- 90 ohm ceramic level sender resistor
- Non-tapered pump outlet and return tubes for maximum flow / performance.
- Tubes have smoother radius bends for maximum flow / performance
- 100% Plug & Play dual-circuit weather-proof harness with pump indicator outputs
- Includes a new stainless-steel locking ring, OE-type tank gasket
- 2 x Walbro 255LPH High-Pressure Pumps
- 2 x 30-micron Filter Socks
HARNESS FEATURES:
- Plug & Play (no cutting or splicing required)
- Weatherproof factory connectors
- Heavy-gauge automotive-grade copper wire
- Heavy-duty weatherproof relays
- Weatherproof fuse holders
- Pump power indicator lamp outputs
- Swapable primary / secondary pump control connectorsÂ
- Dual in-tank 14-gauge Teflon wire harness with Walbro connectors
- Pressure tested bulkhead / feed through connector
- Alternator-direct power for maximum pump performance
- Silicon grease, spare fuse, wire ties included
- Stainless steel mounting hardware
- Choose a 4, 7, or 15 PSI Hobbs pressure switch with interface harness
- Body ground upgrade with battery nuts (included)
