Just as the title says. Bison hooked me up with a new turbo for my GN, I have it installed on the car but have a couple questions:
1. I'm getting some turbo flutter at or around 12 psi. If I step into the throttle a little more I can get past it, but its present during gradual acceration.
2. My stock turbo has a vacuum port on the compressor side for boost control, but the replacement turbo does not. Do I still run a vacuum line to the wastegate actuator also? I have test drove the car both with and without, it seems a bit more lag without the vacuum line to the actuator but does create boost eventually. The flutter I previously described is present both with and without the vacuum line to the actuator installed.
Any and all help is greatly appreciated, thanks!!
