New transmission just blew fluid out filler neck
LEGACY_GN
12 pounds of boost and transmission blew massive amounts of fluid out of filler neck. What happened?
I have the same thing going on with my trans at about the same boost level. I was told it was the convertor possibly. Then I was told it sounded like a warpped pump. This may sound like a dumb question but was it over filled? My vent was clear, the trans was not over filled, so I too am looking for a possible answer. Post back when you find the fix please.
Trans could be over full, it could be overheating, over full and overheating, a seal on input shaft could be damaged, pump pressure release problem. These are some of the most common issues.
