New TSM record
434nova
721
44
28
60's weren't where they should have been. This was in hot and humid conditions in BG. Turbo is a 7168 .85 3 bolt on 28psi, which was maxed out, and a stock location intercooler.
109 block or stage 2? Your flying regardless. Congrats.
NyBlankets
333
32
28
NY
Congratulations Rob! Whats the motor turning and an in car video? Curious on which TC you're running and specs?
forcefed3.8's
Buckeye Bullet
May 26, 2002
3,570
604
113
37
North Ridgeville, Ohio
The converter is too loose actually. It worked great with the 4 bolt turbo I used to run, but the 3 bolt is hindering rpm. I have an 18 blade PTC. Going to switch to a 16 blade. Flash with the 18 blade is 6100. I am shifting at 6400, but it is tough, so I hit 6800 to 7000 at times. 6000 is where I would like to shift.
SpeedRacerX
910
228
43
51
Southern NJ
I just noticed this thread. What stock location intercooler supported this insanely fast run??
Sent from my SAMSUNG-SM-G900A using Tapatalk
Hahny
471
139
43
45
Maryland
New TSM record again. 7270 3 bolt turbo on only 28psi, it has more in it. Track wasnt there earlier in the day, so left soft. It was a mad thrash to make it to BG car was untested. Unfortunately 1st gear went out 2nd qualifying run and i couldnt make eliminations.
Wow...you got that car dialed in!! Congrats forcefed3.8's
Top Bottom
