New wheel/tire pic thread
Tori
Since the old thread with 60+ pages of wheel and tire combo's is useless. (no pics) can we start a new one ?
Post up what your running and lets see'em
17x8 in front 15x10 rear
US Mag Rambler M110
Front 245/45/17 7" wide rim
Rear 245/40/17 8" rim
15 x 8 alloy GN repro wheels. 235/60 tires front, 245/60 rear. Have 2 additional 15 x8 wheels with 275/50 drag radials.
Thank you for posting that, i'm shopping tires and want to go a little larger in the back. I may just try the 245's
If you want a little larger yet on the rears you can go with 275/60 if you don't mind a little rake and a bit more speedometer error. An even wider option is the 295/50 that is about the widest you can go. But, be aware that you might need wheel spacers and longer wheel studs and have to select wheel offset very carefully.
Two poor quality screen grabs from youtube videos are attached. Does anyone have any idea of the manufacturer?
Budnik GNB wheels. 18x8, 18x9.5. 245/45 & 285/40 Nitto's
Thanks . Guy , when are you going to come to BG
Not this year, maybe I can make it next year. It's a long haul from Phoenix!
Holeshot holestar wheels
15x4 fronts (i have to check tire size as i have increased the size and lifted the front more)
15x10 rears no offset - 295-55s. rolled fenders with minimal rubbing around corners
cheers
cheers
I've been looking at Holeshot wheels for another rear wheel set up for slicks / track use . They have a wheel/beadlock combo that is similar to the Champions I have and can't get any more .
Bates 2022
American Racing Torque Thrust 2
20x8 all around
255/35/20 all around
