xtremexnyc
- May 29, 2001
I will be getting my car inspected in about a month. I'm just looking for some tips and tricks to help the car pass NYC inspection.
My set up
TE-44
ESP FM
Tinman Cold Air Kit
adj fuel reg
009 inj. with Jim Testa and Reds Chips. Jim Testa chip in the car now.
Walboro 340 Hotwired
Powerplate
THDP
Test Pipe
ATR single shot
Rebuilt heads
New valve springs
206.206 cam
I will be changing the plugs Acr43ts gapped to 35, wires, fuel filter, test the egr, oil change. Do you think I will need to replace my 02? It is about 1yr old never used any race gas or fouled it. My only problem is my test pipe is welded to the THDP. I do have random tech cat but looks like I will have to hack the THDP to install it. My fuel pressure is currently at 42 with the vac line off. BLM is at about 110 to 115, AF is at 5, 02 sensor does not seem to look lazy. Do you think I would have a chance passing with the test pipe? Also which chip would run cleaner for emissions. This is what information I can think of so far but if you need any more please post. Is there any gas additive that I can use to help out ex. Guranteed to pass, Dry gas etc etc. NYC guys please chime in also. Any tuning help would be greatly appreciated.
Thank you all.
My set up
TE-44
ESP FM
Tinman Cold Air Kit
adj fuel reg
Powerplate
THDP
Test Pipe
ATR single shot
Rebuilt heads
New valve springs
206.206 cam
Thank you all.
