seedling
- Jun 17, 2012
OK,
I just got my Uncle's car ('87 GN - he was original owner) and it had been sitting 7-8 years, maybe? So I did the whole "Spring Cleaning" as was suggested herein! And in doing so I learned a few things about the car. And hopefully you all can tell me where to go from here! (MODS IF THIS IS IN THE WRONG SPOT THEN PLEASE REDIRECT ME AS I AM MORE THAN A LITTLE ADHD HERE AND TOTALLY MED FREE TOO)!
THE MODS:
The car is pretty stock aside from a gutted out cat., an upgraded Turbo (not sure what size but I'm told a GNX Turbo) and it has a Bowling Green Customs over-sized Intercooler (in stock location), some sort of Bowling Green Customs boost control kit (under hood), a boost gauge on the pillar and the chip (that is named after some guy from Illinois is all I know). It does have stock injectors, no fuel pressure regulator and a set of Air Bags! And I'm sure that I missed something.
Oh yeah and my Uncle is still looking for the Scan Master and the Alky Injection Kit.
Anyways I had to put a fuel pump on it to get it going (it had a Bowling Green Customs 50psi unit in the tank). But, now I have it running on some el cheapo Bosch unit - which I will probably replace soon anyways as I must have stuck the float somehow in the install (since the gauge no longer works). At any rate, the car started right up and everything sounds great!
20LBS of BOOST (seems high but I don't know):
The one time I did hit it pretty good (about a 25-30 mph roll), the car took off and of course it broke loose and burned the tires all the way through first and second. And the thing that concerns me most is that the boost gauge on the pillar said 20 lbs. And that seems awfully high to me! And I know that jhanson1750 had recommended that I get a new "turbotweak" chip before I hurt something! Well, now I see why!
And while it did not detonate and it pulled real hard, however I only have six gallons of pure Premium Fuel (93 octane no ethanol / just real gas) and it has a can 104 Octane, plus a can of Lucas Fuel Injector Cleaner and a dose of Lucas Fuel Stabilizer (upper cylinder lubricant). But with the 20 lbs of boost I'm thinking that I need race gas (just to keep from hurting anything)!
So what is stock boost? And should I be worried?
Any feedback is welcome and appreciated!! As I'm all ears!! Thanks Guys!!
THE MODS:
