My powerlogger is set for AEM gauges. I worked with Eric when we set it up to make sure my config was correct. I think my 60 ft will only improve if I get the launch at a higher rpm. This weekend I launched at about 3,000 or almost 7 psi because I was used to the car rolling at the light if I exceeded 2,800. Perhaps a little more aggression will be the key. The converter may need me to help it be better.My bad my logger is set for AEM gauges. Must be not correct to see your A/F Your sig said AEM and I assume it was the same as mine.I have over thought your time slips and log trying to find my on problem that is somewhat like yours
