Welcome to the Hot Air!!! lol...You picked a tough underdog, but like Buickpower stated, set your goals now,a nd it may cost less in the long run. I have very high hopes for my car, and as such, it has sat 5 years now and counting! Also stated before, exhaust! You need it bad!! THe very basic mods are always:
Exhaust-Headers, downpipe, cat-back, or not cat...Mease has a very nice 3" downpipe avail....and ATR still sells an entire system for the hot air cars including up-pipe and downpipe.
COMPUTER- and eletrical up-grades: go with an 87 computer, and caspers will take care of the rest-Ugrading the computer and components offers a huge chip selection, and more information from the comp for better tune-ability.
Also adding electric fans, upgraded MAF sensor and so on can only help.
PORTING-With the motor apart, gasket matching should be the first priority, aside from the basic rebuild. Forged pistons are the only way to go, I have TRW's in my hot air. The porting should be done by the same machinist, so that he can closely match the heads and intake...felpro MS9033's I believe are the gaskets you'll need. Opening up the intake ports and head ports will maximise flow from whatever turbo will reside ontop of your intake. If you remain stock, consider porting the exhaust elbow (where the downpipe connects to the turbo). Opening that piece up will help to eliminate restrictions as that exhaust tries to escape.
Turbo-Injectors-Fuel Pump-Wastegate-Adjustable Fuel Pressure Regulator (ADJ FPR)-
These are all otehr parts that should be looked at, replaced or upgraded.
You most likely have a non adjustable FPR, and so that must be changed out as soon as you upgrade the fuel pump and possiby the injectors. The turbo should also be rebuilt, or replaced with a John Craig TA33c unit....
As per boost and all that to get ur car up to snuff-ALKY!!!!!!! Always keep this option in the back of your mind-Alcohol will broaden that boost band, to where you can put pump gas in and run 20+ lbs of boost,a nd experience no knock.....THe other alternative....I hate to say it...An intercooler. Many people opt for an intercooler for the big bang for the buck....Although far from stock, it can bring huge performance gains to a hot air buick motor. Good luck, always ask, and we can help!!!
John
