SignUp Now!Timing chain had been changed...He used and supplied me with ZDDP...HP fuel pump installed and adjustable fuel pressure regulator. Gotta decide on a replacement for the poston chip.If it was 1987, and the car rolled off the assembly line, it would likely make 3 years/36K. Be smart, update the fuel system, get a good timing set, run ZDDP, update the chip, be smart, learn from 33 fucking years of experience.
Turbo tweak 5.7 chip for pump gas. Easy to adjust with a scan master if you want to make changes, but with the specs you give Eric it will run great right out of the box.Timing chain had been changed...He used and supplied me with ZDDP...HP fuel pump installed and adjustable fuel pressure regulator. Gotta decide on a replacement for the poston chip.
"It's just a matter of time." Brook BentonNow you started another whats the best oil thread. Well, it has been a couple weeks since one.![]()
there is one other ...very rare ...coolant additive which provides the pinnacle of lubrication for the system...it is very expensive due to the harvesting process...and I only know of one place to get it...A lot to digest. Just wondering how important these mods really are if it made it 130k miles without them.
I also been made aware of some leather conditioner that us rare but supposedly very good.there is one other ...very rare ...coolant additive which provides the pinnacle of lubrication for the system...it is very expensive due to the harvesting process...and I only know of one place to get it...
Do you plan to continue adding ZDDP or purchase oil with it added?...He used and supplied me with ZDDP...
I wonder if it comes from the same source...I also been made aware of some leather conditioner that us rare but supposedly very good.
I had the qwik lube use synthetic. Do I still need to use the ZDDP?Do you plan to continue adding ZDDP or purchase oil with it added?
Dino or synthetic?
What filter did they use?I had the qwik lube use synthetic. Do I still need to use the ZDDP?
You still need ZDDP.I had the qwik lube use synthetic. Do I still need to use the ZDDP?
You don't wan't to add ZDDP to an oil that has very low levels. There is a relationship between detergents and ZDDP. If the ratio isn't right,bad things can happen. You want to use a 5W-30 oil that has plenty of ZDDP added by the oil formulators.You still need ZDDP.
you still need this and have not asked for available or even what it is ...there is one other ...very rare ...coolant additive which provides the pinnacle of lubrication for the system...it is very expensive due to the harvesting process...and I only know of one place to get it...
better to fix now than latter ...whats the ole saying ...better to pay now than latter ...He has a car with 130K on it. RMI will exploit ANY weakness in his cooling system, if there is one.
What's RMI?better to fix now than latter ...whats the ole saying ...better to pay now than latter ......and good to clean the block and heads out ...
