- Sep 21, 2018
LOL... you see what you started ..with these jabroneez...LMAO...sounds like your on the right track...start with spring cleaning and maintenance which is most important right now... then get rid of the chip get a TTchip ...translator and newer style MAF depending on goals...and scan master..you do not need an adj. fuel pressure regulator..unless going up in fuel injectors..which will also be determined by your chip....then start in on new timing set and valve springs and ditch the flow master exhaust ...it is a chambered muffler not ideal for turbo cars... free flowing Pypes race pro system are a favorite with guys..the street pro mufflers are a little louder if you like ...GL and welcome aboard..
