News flash!!!!
Hope it works out for you. Did you say that you pulled the pistons to inspect the rings? If so did you put the same rings back in?
Jeff
Jeff we didn't pull the pistons out but by the looks of the piston walls they look and felt (smooth as a babies butt) we assume by this that the rings were just fine, we went ahead and replaced all the bearings and such and checked clearance fore everything, engine turns smooth but tight, I say he is good to go..
yet another day at the office.
here are some pics from yesterday as we dropped the motor in Rays car.
1st pic ray a bit happy is almost done
2nd pics watch out new engine is installed
3rd pics nordy playing surgeon
4th pic there she is ready to go in.
5th pic nordy not paying attention and ray focused on not dropping engine on front panel as usual.
A few more pics.
here is a few more.
1st Nordy playing mecanic
2nd Nordy farting
3rd checking for wetness
4th Ray doing what he does best.
5th the middle man is what i be using to go after Brents tires when he is not looking.
nordy's weight in and mine as well with certificates
Nordy weight in with 1/4 tank of fuel mine with 1/4 tank..
1- my certificate
2- nordy's certificate
3-my car's weight on the scale
4- Nordy's car on scale
Reply!
Enough of this pornography! Who cares what you gays are up to ! I think I'm going to shoot myself for starting this thread!
Pornography? I thought it was a preview for that donkey show "Nacho Libre"
:rolleyes: BTW, how was the leverage with that new "beer belly" cherry picker, model # 40ozx5? I bet it came with it's own self pronounced instructions that had no ending and had it's own idea of how it "should be done?"........
:rolleyes: Whatever Harold I don't think I need to worry about my tires because the knifes on your wall are just like your car "conversational pieces". :D
Take a walk on the wild side!
Chevota is good to hear a voice of reason once more. I'm afraid that this southwest section has reached a new low. For some time now it's been apparent that Nordy & wicked have been an item.They are now turning Ray over to the other side, How long before they will have to be accommodated with their own alternative life style forum. It should be called ( happy endings )They have completely erased any doubt that Calif. is indeed the land of fruits,nuts & flakes.
:rolleyes: blah blah blah blah as usual, and not a word when approach at the track Puss*. BTW the leverage was great it helped a lot, also read my shirt is meant for you. :D
Maybe you can make chevota your new sheep baaahhhhhh, don't be butt hurt because we are learning to work on our own cars without having to depend on your greatness and even if in the process means breaking a few parts here so be it., by the way, you have lived in california longer than any of us put together, does that mean you are a bigger Nut,Fruitcake and flake than we are or maybe some of yours finally rubbing on us? :p
wiked
