Last year i put a pts shift kit in. After the install the 2-3 shift was late only after the
car warmed up. When cold it shifted fine. Probably made a dozen track passes with
it like this and in wot it sometimes shifted late and other times shifted fine.
Went to the track tonight and on the first pass it went to 5800 and i had to let off
for it to shift to 3rd. I adjusted the tv cable and made anouther pass and the trans
never shifted to 3rd. Adjusted the tv cable other way and it did the same thing. Had to\
drive the car home from the track at 35 mph in 2nd gear. I'll pull the pan tommorrow
to look for anything obvious, but what do you experts think i should check.
tranny has 128k on it
