no alky yet...TT 93 chip or TT alky chip??
spoolinV6
I would like to eventually put alky on the car this year and i cant wait any longer for a TT chip. I was wondering if i should order the alky chip from eric and just not go over say 10 psi until the alky is installed or get a 93 oct. chip which i can also use with the alky as well.....
does it really matter between the two chips...i know the alky chip has a little higher timing but both can be used w/alky
thanks
IMO 93, then you can up the timing once you get the alky installed. Thats the route I went.
x2 you can run the alky on the 93 chip and change timing on the chip untill you sen it back to Eric for an alky chip if your not planning on installing the alky right away
I'll be gettting a 93 street chip soon, you can always have the chip redone for alky or get another chip for alky and have one of each.
