- Dec 7, 2002
What will we use instead of coilpacks if they become obsolite? MSD or what? Also, other special "sensors" etc. Has anyone replaced their coil pack with something better for a stock un modded car?
SignUp Now!Originally posted by turbo buicks
im not sure but i saw a pic of bruces car and it looked to have a coil-on-cylinder LS1 type ignition. im not sure but i saw some wores coming out of a thing on the valve cover which looked like an ls1 ignition. is this correct bruce?
Originally posted by FreeJack
From what I am reading, I can go to any 3.8 front wheel drive car, IE... 94 Buick SkyLark with a 3.8 engine and a Type II coil and plug it right in and it works???
Originally posted by 6=8
A fairly easy conversion is the Type II style upgrade, consisting of a new ignition module, mounting bracket and 3 separate coil packs.
The only real change you need to make to your stock setup is the spark plug wire routing.
OEM coil packs had the plug towers on the back and the front sides, where the new coils have both towers on the back.
You need about 2-3" more length for #2, #4, and #6 plug wires.
