john saleeby
- Aug 5, 2006
Problem- No dash, tail, running or shift indicator lights on my 87 GN. Brake lights, head lights, turn signals, hazard flashers work
What I've done/checked- changed 5A INST LPS fuse, 5A CRUISE fuse, 20A TAIL LP fuse, and 20A GAUGES fuse. These all have power to the fuse holder and were changed even though they did not appear broken
checked/cleaned ground on left side of car trunk. checked ok
checked/cleaned grounds on the firewall behind passenger side valve cover, driver side fender and firewall on driver's side
checked wiring under center console near shifter handle ie common problem- checked ok
Tried to check for the reported common problem of a white whire that makes a sharp bend over the stering column. I removed the gauge bezel and but did not see a white whire or it's connector over the steering column
Any advice, things to check, new switches to buy LET me Know, I'm stuck.
