In order to make the drum stronger the pilot area in the drum is bored out to a shorter depth.This is done to increase the cross sectional width material at the fracture point.This internal bore of this area is not a torsionally loaded area but a path for lube oil exiting the center support to get to the overdrive planetary as well as a rear pilot to hold the input shaft and od planet on center .If you dont shorten the input shaft it will bottom out on the floor at the base of the inside diameter.It is a very simple modification.Our input shafts are all made to the shorter length regardless of drum type with NO side effects.
