No Heat
83turbomon
Starvin Like Marvin...
I got my heater blower fixed, but I still dont have any heat and in Washington that is a must... I think that my heater core or vents may be plugged... any advice...?
Might be that cold 160* thermostat.
Confirm heater core operation buy feeling the lines that go and return from the core.
one should be cold, and the other hot.
if both cold, disconnet return side and check for core flow.
if no flow.... core is likely plugged.
:biggrin:A.j,
:biggrin:A.j,
Partially true Aj. There's a valve inline that may not be working. If one line is warm and the other is cold check on both sides of the heater control valve. You may have a bad one or the vac signal isn't getting there.
forgot all about the water valve!
ive gotten used to the manual ball valve in mine!
A.j.
