No Power off the line
Just want to update because I hate it when people start threads and don't follow up.
I did confirm that the cat that was on the car was gutted. But i have now installed Pypes 2 1/2" dual system with the race pro mufflers with a test pipe. Welded up a crack on the driver side header. Installed new Comp Cam 981-12 valve springs. Installed Tin Man CAI for stock MAF.
Fuel pump, hotwire kit and adjustable FPR are all on the way and should be installed next week. I also have an AEM wideband gauge that needs to be installed.
The result is that once underway the car has a lot more power, but is still a dog off the line. I think it may be torque converter related as the converter on my car has a "6" stamped on it. However under WOT I am only seeing about 13 lbs of boost. Not sure why.
Did you get the pcv leak fixed? If your fuel pump isn't keeping up that might cause ( or go hand in hand with) the limited amount of boost at WOT. I would install the new pump ASAP and not beat on the car until then.
The PCV valve has been temporarily blocked with an expansion plug. I have a new Grommet I would like to try this week. Once my fuel system has been upgraded, I will report back with where I'm at.
I am cutting 2.0 in the 60ft at the track. The sucker would have no power off the line at 4 pounds of boost. It would sorta bog and spool slowly to 15 pounds and then hit hard to 26 pounds the rest of the track. I had gotten a few things switched out and added a few things and heading back soon. Phil (pdzz) who I bring it too says I needed a high stall and will probably be getting once soon. The most dramatic change was putting stock headers on over the hooker ones that were on there. I got the same valve springs, gbody rear brake kit, plugs and wires, wideband and fuel pressure gauge. Hoping this helps me cut under a 2.0 60 ft but I would say I need a converter. I still can't boost more than 5 pounds before it starts pushing through. I can definitely say it hits hard and feels stronger than before, the spool up is quick also.
Many threads claimed that Flowmaster are bad for TR engine, flow restriction, try replacement and see what results you gain.
With everything I've done the car has a lot more power now at speed, but still a dog off the line. I've already established I have the wrong TC. So I'm ready to start thinking about which TC to get. My upgrades are listed in my signature. I don't intend to make any more performance mods but want the car to be a nice street performer, it'll probably never see the track. What would you guys recommend? I was thinking about a 2800 RPM stall.
Put it this way, I went with a ptc 10"2800 stall fr dusty B. Now I need a neck brace.
How much would a PTC or Husek TC set me back?
Also, is it agreed a 2800 RPM stall is good for a GN with my specs?
Yes. With a stock turbo, 3000+ spools too fast if you can believe it.
With a higher stall converter comes more trans fluid heating. Get a stacked plate trans cooler also to run in series with the one in the radiator.
My Husek 3021 LU cost me $500 + shipping a few months ago. I believe he has 3 versions of this converter in LU with different price ranges all the way up to a billet cover. All depends on your needs.
A stock turbo with a 2800 should rip the tires off. Your actual stall # will be dependent on your build.
Ok so after speaking to Dave Hudak I ordered his TC. He recommended the 3021 so that I would have room to grow.
While I have the driveshaft and trans out I am going to change the rear pinion seal, trans output shaft seal and the drivshaft u joints. I dont need any bullet proof but might as well upgrade the u joints. Any recommendations?
I have Spicer 5-375X I think. If you go to a supplier they can look it up by car application. It is real close to that number.
Ah, that makes sense. I talked to a driveshaft shop a little bit ago and they're gonna balance it and install the u joints for $130. I thought that was a good deal.
Just make sure those snap rings are installed on the end caps and mount inside the rearend yoke. The driveshaft can spit out under power. I had my driveshaft balanced and that was about what I paid also, yours may be just a little cheaper. Congrats!
New TC going in tomorrow. If thr new trans mount shows up tomorrow it'll be on the road. Hopefully this solves the no power off the line issue.
