no power
ITzABUICK
This thread has prob been made be for but I cleaned the tank after the car Sat for a yr New fuel filter put sea fome in the tank new plugs under load has no balls wants to stall so I can think it's clogged injectors has 72 lbs injects in it and only putting out 30 to 40lbs psi runs fine at idle any thoughts thanks in advanced
please post your mod's. If you have a hot-wire kit, etc, it will make diagnosis much simpler.
If you can't adjust the f/pressure to 43# w/vacuum line off, put a clamp on the regulator return line and the fuel line pressure should rise to what ever your f/pump psi is rated for, at a given voltage. If poor results, it will be related to the pump, voltage, bad gauge, etc.
