NO START WTF
luisturbog
UNDERDOG HOT AIR !!!!!!!
I'm all out of ideas. I can't get my t-type started. Went through all the checks. Cranks over fuel pressure tested out fine. Just checked crank sensor & it works fine good signal. Injector pulse checked with noid light it works. I'm not getting spark changed coil pack with module from running car & still no start. I'm stumped. Someone help.
Just in case u were wondering, all parts are new. Crank sensor, cam sensor (caspers top) coil pack & module. New turbo tweak chip.
Were the wires swapped to work with the 86-87 module?
If you've gone through all that I would try changing the esc there's a module near the map sensor that controls the spark if that doesn't work try a good ecm but before I would check the wiring harness completely
That's definitely a different idea, esc module. I hope it's that simple cause I'm burned out with this problem. Been on it a week & it's killing me. Lol. I'm gonna do 1 last continuity check from ECM to module just for shits n giggles.
It can be frustrating. Did you follow the no start tree?
Yeah. I read that whole thing too. From all the checking I've done this thing is supposed to fire up. I got my Buicks side by side 1 runs & the other doesn't:-(
I hope it's this simple....in your picture, there is no o2 sensor nor a MAF sensor...?
Is this a new build?
The newer one. This is the ttop one I got for $1000. I was gonna use it as a donor car for its rear end but ended up Falling in love with it. Lol. Ttop, center console, originally blue + engine had been rebuilt but never fired up.
