Non Lock Up - Xtreme 2004R Killer Street/Strip With NLU 3800 Converter
deleonl
N.S.D.Q
Non Lock Up - Xtreme 2004R Killer Street/Strip With NLU 3800 Converter and Slapper Trans Brake
Tranny was purchased new from PTS Extreme Transmissions in 2002. Previous owner had the tranny freshened up before I purchased last year, currently 0 miles. The tranny has sat in my garage covered for a year or so, my plans have changed and I need to make room. Just to clarify this tranny has a built in trans brake that works in 1st gear, if you have any questions feel free to give me a call.
Below is a part list of the internals
* HARDENED PUMP STATOR * 7 VANE HI VOLUME PUMP KIT PTS SUPER PUMP ALL GM PARTS * CHROME-MOLY PUMP RINGS * .555 TV BOOST VALVE * .300 INT BOOST VALVE (PTS.400) * PTS BILLET SERVO (PTS-11) * RAYBESTOS "BLUE PLATE" DIRECT CLUTCHES * ALTO 2 3/8 inch H/D BAND * 300m BAND ANCHOR * ROLLER BEARING OD CENTER SUPPORT (PTS-6B) * TEFLON C/S RINGS * BILLET INPUT SHAFT (PTS-300) * BILLET INTERMEDIATE FORWARD CLUTCH DRUM SHAFT (PTS-1) * TEFLON PUMP & DIRECT DRUM BUSHING * PTS "BOTTOM FEEDER" FILTER/SUMP SYSTEM * PAN DRAIN PLUG * VALVE BODY & GOVERNOR MODIFICATIONS * HARDENED H/D DRIVE SHELL * ROLLER BEARING L/R CENTER SUPPORT (PTS-7) * ROLLER BEARING PARK GEAR SUPPORT (PTS-3) * ALUMINUM PAN (DEEP) * SLAPPER TRANS BRAKE
$1500.00 firm for tranny and converter
I have a copy of both pressure test and rebuild receipt that was given to me when purchased.
(813) 309-0144
Very interested....who made the converter and has it been freshened up as well?
Thanks, Bill
Thanks, Bill
I had the PTS 9x11 converter but sold it, the converter that will be going with the tranny is a used and has yet to be freshened up Mark Williams.
I would have to look at the receipt, but if I'm not mistaken it was a different shop that freshen the trans. Have gotten alot of phone calls and PM's but nothing firm yet.
Did PTS freshen up the trans or some other shop?
Thanks, Bill
