NOS or OEM or NEW Parts for sale
HarryK
Cleaning out the garage and the GN is long gone. Here are some parts I have still in the boxes..I'll try to attach photos. Most were bought from Kirban's a few years ago. I have them here at about half price which I think is more than fair. All parts are NEW, OEM or NOS unless noted. I’ve included the part numbers from the Kirban catalog so you can look them up in addition to looking at my actual photos. Preference to multiple item orders! Shipping is whatever it comes to. No surprises:
Body Mount items:
7 total Bushings: ($20 for all) 22 parts below ( $20 for all)
488610 (2) (3) Diamond body nuts
348080 (2) (6) Washers 337559
377801 (1) (6) Stock black body boltsGR8
457941 (1) (7) Upsize bolts
25509026 (1)
Emblems: (USED)
T-type (2) $5 each
Grand National (3) - $12 each
Intercooled (3) - $8 each
(NEW) 3.8 SFI Turbo emblem, bent at “8.” But not noticeable once mounted - $12
(NEW) “BUICK” goes on front grill - $10
Miscellaneous:
New reman brake Hydroboost w/bowl - $300
NEW MAF sensor rebuilt Cardone - $50
NEW 3/8” Main fuel line complete - $75
NEW Group of six plug wire holders and harness holder - $8
NEW Upper control arm bushings - $12
NEW GM PCV Valve – $3
GN lug nuts (10) - $1 each
T-Type lug nuts (16) - $1 each
McGuard locks w/key - $15
NEW Coil pack -- $75
Coil pack and module USED - $75
NEW GM upgraded Power steering Res - $20
NEW Transmission mount - $12
NEW Valve cover gaskets - $6
Two thrasher chips (see photo for specs) $15 each
Used stock turbo – VG condition - $120
NEW Cat bypass pipe - $20
Front sway bushings (slight use) - $12
NEW, NOS, and OEM items:
1546 K&N Filter Kit 8" - $25
6696 Adj Wastegate Actuator - $45
6891 Engine mounts - $17
6533 Knock sensor - $20
6751 Fuel pump feeder wiring kit - $35
1580 Pass side breather kit - $10
1586 Rear seat brace kit - $40
6564 Front frame braces - $25
6888 Oxygen Sensor - $25
6746 HD 100 LB valve Springs - $20
1588 Turbo Oil feed line - $15
6561 Rear pinion snubber - $15
6697 GM Accumalator bowl -
6653 GM Center cap (USED) -$15
6578 Driveshaft loop kit - $20
6826 High Heat Spray paint $7
6822 Gray Interior Spray Paint $8
6645 PCV Valve $3
6982 GM Pass valve cover and PCV grommets - $7
6599 Fan Delay Relay PN-25527402 - $19
6943 Power Steering hose - $18
6644 Boost line kit $15
6781 - A/C Blower relay - $12
6609 - Dayco drive belt - $16
6595 - Heater hose kit - $18
6625 VDO Water temp gauge - $30
6626 VDO Oil Press gauge - $40
6827 VDO 30 LB Boost gauge - $30
6533 GM knock sensor - $25
1529 Twin Gauge Holder - $15
Please Email me at Quebec100@aol.com and I'll send you all of the photos.
RW87TT - OK..you reserve 6625 6626 6578...1529 is gone. Please EMail me at Quebec100@aol.com with the list so I can keep everything organized (Inlcude you RW87TT handle)
Harry K.
new gm pvc,new tranny mount.1588,6599,6781,engine mount,used coil pack & module.pm me youre address.
I'll take these if still available E-mail sent
Thanks!!
Tony
Humble, Email me the list at Quebec100@aol.com with your name 'Humble'..I have to sort everything out tomorrow I got about 12 Emails in a row..but you're good on most of your stuff for 1st pick
I'll take these three if the shipping is reasonable, do you take PayPal?
What color is the high heat spray paint? I may want that also.
My e-mail is Hairy@centurytel.net
Zip code for shipping is 48455
Please advise.
Tim
6751
is6751 the hot wire kit for the pump if so I'll take also I'll take 6625 &6626 ,the inter cooled emblems and the grey inerior paint if still available thanks. itried to email but it came up error dont know whats up please reply THANKS
OK OK OK...too many Emails, PMs and Replys!
Sorry, I'm not set up to handle all of these requests right away..I tried my best to commit to first come first served....I've replied to the EMails inthe order I've received them and sent photos and other descriptions. Here is what is not spoken for so far...Please understand I've received 14 Emails and 9 PMs for these things and it was difficult to sort out. I will re-group once I find out shipping costs for those I've promised items and if they reneg, then I'll go to the next person in line. For now, please look at the list to see what's left:
Emblems: (USED)
T-type (2) $5 each
Grand National (1) - $12 each
Intercooled (1) - $8 each
Miscellaneous:
Front sway bushings used, great condition - $12
PHOTOS AVAILABLE ON REQUEST..EMAIL ME SO I CAN REPLY WITH THE ATTACHMENTS
Quebec100@aol.com
Harry K.
