Nos performance and stock 84-87 parts LOTS
wickedsixx
NOS PARTS
Accumulator Ball 18038507
Intake pan gasket 12328760
(3) Head gasket 25528486
Coil pack 12353801
Knock sensor 10456287
(6) 42TS Delco Spark Plugs
3.8 SFI Emblem 25519633
Boost Line Y kit
Down Pipe to Elbow Bolts with Springs GM?
NEW AFTER MARKET PARTS
Rol Extreme Cork Rubber Valve Cover Gaskets
Felpro Timing Cover and Water Pump Gaskets
Accufab Fuel Pressure Regulator
Energy Suspension Poly Front Control Arm Bushings
12pt ARP Rod Bolts
Down Pipe to Elbow Gaskets
Boxed Lower Control Arms Black with new Bushings
USED AFTER MARKET PARTS
(2) Cam Sensor Setting Tool
30LB Injectors with Start up time only
ARP Head Bolts
Low Mile Roller Springs off ESP Heads
(2) RJC Power Plate for Stock Plenum
USED 86-87 PARTS
Stock ECM Chip
Stock Head Rest Seat Belt Guides
Iron Brake Drums
(7) 2. Rods
Set of Heads bare and clean
Turbo Shield
Maf Screen
Intercooler
Intercooler Shroud
Side Body Moldings
Aluminum Drums ready to go
All 86-87 Sensors
Intake clean and repainted used Sensors w(2) New Hose Nipples
Plenum
Plenum and Throttle Body
Throttle Cable Bracket
Flat Coil Bracket
Round Coil Bracket
Fuel Rail
Coil Pack
Coil Pack Module
(2 )Belt Tensioners
84-85 PARTS
Stock Block clean
Heads
Intake Manifold clean and repainted
Brackets
Sensors
Engine Harness
Down Pipe
Up Pipe
Complete Turbo
Fuel Rail
Turbo Adapter
Throttle Body
84-85 GM Wheels with 215/65/15BFG on front and 235/60/15 Dragradials on back
5 passes and approximately 100 miles on all tires
Newer GTA/GNX Wheels 245/50/16 Firestones 95% front 45% back with caps
and chrome lugs
I'll put prices on soon until then pm an offer and I'll get back to you. Email for pics. I have more parts but I am just posting these for now.
Thanks...
Brake Accumulator is gm second version with the yellow label.
Yes I take pay pal.
Shawn
There is a bolt holding the set together and I didn't have a wrench when I too the pics but you get the idea.
Intake pan gasket
Price on intake pan gasket. Should have put these all on one request, Thanks
